MLV and car's hood
There are reflective faced versions of MLV that will protect it but you really want to be sure there's no guarantee it will help. It's worth thinking about since suspending a 1 lb/ft², flexible material over an engine isn't a trivial task.
For a barrier on the hood to help, noise needs pass through the hood and windshield. Most modern cars have hoods that slope forward and windshields that slope backward. The oblique angles make it unlikely that much sound will take that path into the passenger compartment. I've installed barriers on hoods and found no measurable difference.
Most engine noise enters the passenger compartment through the lower firewall and front floor. Even if the barrier on the hood makes some difference you aren't likely to hear it until you cut off the dominant entry points. I encourage people to treat the interior first and return to the hood if they need to. Very few do.
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
222
A Link would be very helpful. Id be interested in taking a look at some gear
228
664
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
randomwalk101
randomwalk101
Houston,TX
randomwalk101
Decebal
    Jun 10, 2024
