mixing wet and dry cell batteries....
aaron7114
Arkansas
I have heard that mixing wet and dry cell batteries isn't a good idea. I'm just wondering why? I have a small wet cell battery under by hood and a kinetik 2400 in the back by the amp right now. My voltage doesn't drop below 12.5. I'm about to purchase a small kinetik to replace my wet cell and was curious as to how much it will help going from mixing wet cell with a dry cell to just having two dry cells.
I'm prolly going to get the kinetik 600 so it wont be a whole lot bigger that the battery I have under the hood right now but it will be dry cell instead of wet. How much of a difference does it make?
Not a whole lot....the main difference IMO is the resting voltage of the two batteries. The dry cell depending on what you buy, can have a higher resting voltage than the wet cell and be drained down to the resting voltage of the wet cell when wired together.
you will be fine mixing dry/wet......... its not the best idea but it will work.
the only problem is that if you leave your car for about a month and dont drive they could be drained
The only reason I see is as Dman said, dry cells like to rest 12.8 +. Wet cells are much lower. This will place a constant drain on your wet cell to charge your dry cell when parked and it won't be at full charge, which will cause it to die faster.
Dry cells supposedly place less strain on your alt, too.
you will be fine mixing dry/wet......... its not the best idea but it will work.the only problem is that if you leave your car for about a month and dont drive they could be drained
umm if that happens your batteries are shot....there is no reason they would be drained....
umm yes it will just like 1 single bad/indifferent cell in battery. the effect is called leaching. if its a daily driver i wouldnt worry so much as i have ran agm and wet cells for over a year and stock battery with 2 wet cell deep cycles for years prior to that. if you leave the car parked for days/weeks and you know you wont be driving remove the fuses between the batteries.
Thank you for all your help and I'll let you know how it all turns out. I'm putting it n a kia optima. I hope that it sounds as good as i think it...
10
Im not sure if this helps or is the correct way but I have 6.5 mids in the front doors and tweets in the pillars I used 2way 6x9s in the rear...
aaron7114
aaron7114
Arkansas
audiolife
    May 23, 2024
    May 22, 2024
