Missing mid-bass? Sub + Alpine SPS-600 6-3/4"
drpeeb
FL
I feel like I'm missing what I guess would be "mid-bass" with this setup:
- 2005 Nissan Titan King Cab (half rear doors)
- iPod Nano 4th Generation 16GB directly into ...
- Kenwood KAC-745 amp (yes, from the 80's, I know, getting old!)
- Alpine SPS-600 6-3/4" speakers (new) in rear doors only (no front speakers right now)
- Kicker KM10 10" marine sub (2 yrs old) in a 1.0 cubic foot sealed box I made out of 5/8" Home Depot particle board, stuffed with polyfill (sounded bad, out of control, with any size port at all)
Two Alpines are run off amp "A" set to high-pass; Sub run off amp "B" bridged, set to "mono" input & set to low-pass.
(So, all sound comes from the back (for now anyway)).
Even when I crank it way up, where the highs are loud/ crisp/ clear and the bass is thumping real good, I can pretty much carry on a conversation! It's like the missing band is almost the same as vocals. Yet, I can hear all the vocals in the music just fine. Vocals don't sound muddled; It just seems to be missing a little "liveliness" or character maybe. Very BAM: "You want highs, you got highs; You want lows, you got lows. Vocals, no problem." Life? or energy ... not really.
I don't know that this is a huge problem, but I certainly don't think it's a very flat overall response I'm hearing. I could also refer to it as "too controlled".
Any thoughts?
(Do you all think these Alpines ****? They seem to bass-distort sooner than I would have thought being set on high-pass only)
Thanks for your input ...
Any thoughts?
Are the rear doors in phase? If they're out of phase it would give a tinny empty sound. A good trick to test if they're in phase or not is to take a AA battery and soldier a piece of wire on both the positive and negative end. Unhook the speaker wires from the amp that run to the doors and touch the positive battery to the Positive speaker wire and the negative battery to the negative speaker wire. You will hear a pop and the woofer should PUSH OUT. Test both to ensure they are both pushing out, toward each other. If one pushes out and one pulls in, they're out of phase and you've found the problem...if its all good
....then, what is that amp crossed over at in High Pass? Turn it down to about 100hz or so if its not already. I don't know that amp...(I was born in 84' Lol)....but that's a good place to start.
Let me know.
Let me know.
Midbass is when the 'impact' sounds of the music, the attack part of the bass note that transitions into lower mid range where the lowest vocals begin, comes from in front. In a properly tuned system it creates the illusion that all of the heavy bass hits and low notes that give your music impact and fullness come from in front of you rather than behind and helps 'hide' the sub frequencies where they can be heard and felt but not perceived as directional. For that you need good mids in sealed doors running off a good amp... IN FRONT of you. Good equipment behind you and stock equipment in front of you simply cannot be properly appreciated by the human ear. Is there any particular reason why you started by replacing and amplifying the least important speakers in the system?
In my opinion there is no problem whatsoever with your setup. It's doing exactly what you told it to do when you picked your components and installed everything. You can hear the sub, and get some sense of whatever's coming from the rears even though it's largely lost on you because it's behind you, then a gap, then the shitty highs and mid range from the stock fronts. It is time to think about front components that can do a convincing 70 hertz or so without screaming for mercy and finding power for them.
I totally agree with your midbass explanation but I took his thread as something wrong with the installation (phasing or crossover point too high) And yes, It makes no sense to start with the rears. Sorry man, no disrespect.
Ahhh ... I wasn't totally clear: I have no sound being produced up front at all! Not using the stock front door speakers. I'm using only the two Alpines in the rear doors and the sub. Nuttin' up front, which as you say isn't optimum, but I'm trying to modify the truck as little as possible: No replacing the HU and prefer not to change the front door/ dash speakers, either, although that plan may change. I want this to kind of be a semi-portable, easily removable system that I can reasonably remove and put in my next vehicle when that time comes: Grab my amp and sub, snip the wires (leave the door speakers), and I'm gone.
So ... I would call the sound I'm hearing very good, waaaay better than OEM, a quality, tight, clear as can be sound ... just lacking in the mid-bass "liveliness" range. Highs, lows and mids are all more than fine for me; It's that area between mids and lows that seems to be missing.
Also, regarding the crossovers (one per amp): They aren't adjustable on my dinosaur. It's 80 Hz .. Hi-pass, Off, or Low-pass. So, the sub is getting 80 and below, and the Alpines 80 and above. What do you think? Is 80 Hz too much to expect from the little 6-3/4" Alpine speakers?
(I appreciate all this info so much I've forgiven your bragging that you're the same age as my amp!!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif ... Thank you!)
OK so again... you wanted to minimize modifications to the truck so you started with the speakers you won't be able to hear first and have absolutely no sound coming from the front of the vehicle? My only suggestion then would be to rotate the driver's seat and drive backwards.
Seriously... Im just trying to wrap my head around why you would wrip out fronts completely and leave rears but I guess to each his own. I am also very skeptical of your suggestion that having no sound coming in front of you is that great but I guess sound really and truly is subjective. Sit in a vehicle with excellent from speakers and see if you still feel that way.
Regardless...you're missing something because you replaced the wrong speakers and in my opinion trying to find some 'fix' for this is a loosing battle. Frequency response is dependent on listener and speaker positioning and aiming.
None taken, originally meant for the OP.
I may still not have been clear ... I didn't take the front speakers out; I'm just not using them! Both the HU and all front speakers have been untouched. I am trying to totally avoid messing with (or even using any more) the HU & the front speakers, instead replacing only the rear door speakers with the Alpines, adding a sub and an amp to power both, and feeding an iPod directly into the amp.
So, you're right in that I'm not gonna have front sound under my current plan. Maybe I'll change my mind and break into the front door panels and replace those speakers at some point ... but, my original question still stands, so I'll re-state: With a sub and 6-3/4" full range speakers (even if they were installed up front!), would it be normal or common for a listener to maybe want to add some mid-bass? Or feel that the mid-bass range is lacking?
By "no front speakers right now," does that mean none are installed, or you are using the factory speakers?
If you're not using front speakers period, you answered your own question.
Why does it sound lifeless when the speakers are about 2 feet behind me, 90* off-axis, and probably muffled pretty well by the front bench.
Makes me ponder.
Makes me ponder.
The factory speakers are there, but are still connected to the OEM HU, which I am not using. I am only using my iPod straight into the amp, which powers the 2 Alpine 6-3/4" full range speakers and a sub.
Yes, I realize this all being behind me will always be imperfect, but I don't think speakers being behind you would cause them to sound great in all ranges but mid-bass.
I think you are misunderstanding me. You think Im just pointing out your speaker position as a separate and unrelated observation but I'm not. You're not getting direct sound, you're getting muffled sound from those speakers filtering through the front seat and random vibrations, reflections, and refractions of frequencies, some of which may make their way directly to your ears and be more clearly perceived by you than others which reflect off different surfaces before getting to you. When the speakers aren't in front of you and aimed and positioned for good response and you start trying things like this it has effects on the way the sound travels that it can be very hard to predict. Alot of midbass/midrange frequencies will be diffused, or muffled and broken up before they reach you. Upper mid range and higher frequencies tend to travel more like beams rather than waves, meaning they may bounce off multiple surfaces before they even get to you but many of them will still get there. It can change based on the size and shape of a vehicle and its interior. Your personal opinion may be that it sounds awesome or even OK but IMHO it probably doesn't. So yes, it is completely 100 percent normal for someone with your setup to be missing something, very possibly in the 80-250 hertz range where alot of sound is more likely to be diffused and muffled by everything it has to travel through to reach you.
People are answering your question and you are not except it. If my sig had more space you would make my 'car audio wall of wisdom'
I think you are misunderstanding me. You think Im just pointing out your speaker position as a separate and unrelated observation but I'm not. You're not getting direct sound, you're getting muffled sound from those speakers filtering through the front seat and random vibrations, reflections, and refractions of frequencies, some of which may make their way directly to your ears and be more clearly perceived by you than others which reflect off different surfaces before getting to you. When the speakers aren't in front of you and aimed and positioned for good response and you start trying things like this it has effects on the way the sound travels that it can be very hard to predict. Alot of midbass/midrange frequencies will be diffused, or muffled and broken up before they reach you. Upper mid range and higher frequencies tend to travel more like beams rather than waves, meaning they may bounce off multiple surfaces before they even get to you but many of them will still get there. It can change based on the size and shape of a vehicle and its interior. Your personal opinion may be that it sounds awesome or even OK but IMHO it probably doesn't. So yes, it is completely 100 percent normal for someone with your setup to be missing something, very like in the 80-250 hertz range where alot of sound is more likely to be diffused and muffled by everything it has to travel through to reach you.
It might be kinda cool to get added to your wall!! "I was so dumb a smart dude added me to his wall of dummies!" My friends would get a kick out of that!!
Anyway ... I also sat myself down right in the middle of the back seat, centered right between the Alpines, so they were pointed as directly at my ears as they could reasonably be, and my original observation still stands: Missing mid-bass. Super clear highs, mids and sub-lows, just not great in the mid-bass range.
Does this change your mind?
Maybe I need a "woofer" instead of a "sub-woofer"?
Thanks again for everyone bearing with me ...
Then you have to go into questions like are those rear doors deadened? How much power are you putting to the speakers? Where is your mid/high crossover in relation to your sub? Having a good midbass/mid range driver is only half the battle. Tuning can make those frequencies jump out at you or seem to disappear completely.
And at the end of the day a cheap coaxial is still a cheap coaxial. Sloppy crossover and usually with cheaper cone materials and overall construction than a good end dedicated midbass/midrange. Issues of installation can affect how much midbass/lower mid range you'll get but may only take you so far in terms of what satisfies you.
Beyond that my mind is unchanged but if this is what you want to do with your sound system more power to you. IF you do get more midbasses I strongly suggest mounting them in the front seatbacks firing rearward for best effect.
Okay, my question is for the OP. How are you getting a signal to your amp? Also do you have the rockford fosgate factory system in your truck? I know in my titan the front outputs are different than my rear. I have the factory RF system which I have a factory amp to all my stock speakers.
I do not have the Rockford Fosgate system, but as I said earlier that doesn't matter at all since I'm using absolutely nothing of the factory stereo. I'm running an iPod directly into my amp which directly feeds two Alpine SPS-600 6-3/4" speakers in the rear doors only, plus a 10" sub.
So, the actual Titan OEM stereo is completely immaterial in this case.
drpeeb
drpeeb
FL
drpeeb
