Mint DLS A3 twin mono
  • 2
tyroneshoes
NJ
Product Brand & Model:
DLS A3- dual mono amp that can be bridged to run at 1ohm for 1200wrms.
Specifications
Number of channels 2
Amplifier class AB
Output power in 4 ohm 2 x 150 W
Output power in 2 ohm 2 x 270 W
Output power in 1 ohm 2 x 425 W
Mono bridge mode 4 ohm 550 W
Mono bridge mode 2 ohm 870 W
Mono bridge mode 1.33 ohm 1000 W
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Input impedance, high level N/A
Input sensitivity 0,2 - 7 Volt
Input impedance > 10kohm
Frequency range 10 Hz - 50 kHz
High pass filter 20 - 200 Hz
Low pass filter 50 - 125 Hz
External cooling fan terminal 1
Dual DC inputs 1
Power consumption (idle) 1,1 A
Power consumption (max) 140 A
Rec. power cable Minimum 2AWG / 33 mm2
Fuses 4 x 30 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight 6,2 kg ( 13,67 lb)
Condition of all items:
Looks brand new. Mint in all ways.
Total Price: :
$375 + shipping from 07065
Reason for Selling:
No longer in plans
Pictures: - Posting a picture of the exact item for sale is mandatory
(Unless you are a DIYMA vendor or your last 5 iTrader feedbacks on this forum are positive, you must include at least one pic with a slip of paper showing your DIYMA user name & the date you posted the classified thread WITH THE ITEM FOR SALE.)
//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
glws bro, quite the sexy amp
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
tyroneshoes
tyroneshoes
NJ
tyroneshoes
