Mint CT 4000.1
  • 2
JRCF71
Mint CT 4000.1
Ratings 1 Ω @ 12.8v
2 Ω @ 12.8v
4 Ω @ 12.8v
4000w rms l 8000w max
2000w rms l 4000w max
900w rms l 1800w max
Technical Specs
frequency response
gain adjustment
subsonic adjustment
phase adjustment
bass boost
signal to noise
damping factor
minimum impedance
low pass filter
strappable
bass knob
10hz to 250hz
0.2v to 5v
10hz to 50hz
0º to 180º
0dB to 18 dB
100 dB
180
1 Ω
35hz to 250hz
master/slave switch
remote gain Control
clip light Indicator
built in volt meter
pushable on-off switch
5400 rms at 1ohm at 14.4v.
Price: View attachment 26547570View attachment 26547571
900 shipped OBO.
  • Locked
Up for grabs is a Gravity Warzone 4000.1 mono amp. This is a solid low budget sub amp that does a solid 1000 or so watts at 1 ohm, maybe a bit...
Have you tried connecting the amp to a car battery? No subs, just power. If it protects, amp is bad. If no protect, subs/wiring or ATX power...
JRCF71
JRCF71
Victorville, CA
JRCF71
    May 31, 2024
    May 24, 2024
