mini second battery question, pic*
Rsx_03
LoW aNd sLoW
i bought a mini interstate battery, 5"x3"x1.5", 7ah for my alarm
i dont think i should hook it up like in the picture //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif , help ... lol
im runnin 4awg wire knukn kullussus, i have an extra run of 8awg, should i run that directly to my red top?
so exactly how does it know where to pull the current from? i would expect it to pull half and half, if it cant pull half from one it will supliment it from the other
you should be fine that way, i would just make sure that you run at least 0 guage to the d-block and you should be fine.
WRONG, WRONG, WRONG.
THE MOST IMPORTANT FUSE is the one you SHOULD have from your battery before the run to the d-block. You still need a fuse near the alarm battery in case it pulls away from the d-block and between the alarm and battery. The safest scenario is to fuse every + wire as it leads away from a power souce.
lol should of mentioned i have a fuse bout 3 inches away from batt and 3x fuses on the distriblock, and my alarm comes with a fuse on each +12v wire
would it be better if i ran a 8awg direct from the 2nd battery to the redtop? i have an extra fuse holder for that also
Rsx_03
LoW aNd sLoW
Rsx_03
miami
Rsx_03
Mike Mccabe
