Midbass drivers
several have had some success with SB Acoustics. I've toyed with the idea but i've since moved away from the concept of random DIY speakers. I have a few laying around still. I ran the Silver Flute woofers for a while with decent success.
no worry about using 8 ohm woofers, the efficiency gains (higher sensitivity) usually make up for the reduction in amplifier output.
the reason most people don't get good midbass is irrelevant of the drivers used and usually the result of the install. my build logs (several in the build log section or linked in sig) are a good example of how to get good midbass out of anything. the doors i build play down to 50Hz easily and with good output.
Just run them at 8ohm until the 4ohm come back in stock. 75w should be plenty each for now. Dont bridge them run one on ch3 and the other on ch4. You wont get a ton more output going to 4ohm.
BCotrell
BCotrell
irvine, ca
dbjunior
vegang
vegang
