midbass and an amp
power range? if you mean how much power they'll get, im not set on anything. just want them as loud as possible.
size wise, not sure. theyre going into a door panel, so i think 8's are probabbly too big, so aynthing in the 4-6.5range id say. but dont hold me to that
people really need to learn how to ask a question before they expect to hear to decent answers...
2 way? Are you looking for a mid that has good midbass output that can still extend up to match with tweets?
3 way? Are you looking for a dedicated midbass that will be bandpass. What will you be using to bandpass the dedicated midbass?
what midrange with you mate with dedicated midbass with (if going 3way up front)?
HU/processing/wattage/info/something?
well im not sure which yet but im going to get some component speakers. so it would be dedicated and i guess then itd be run 3 way then. bandpass?
kk lets try again. just did some researching. this is what i got from it
lowpass-everything above is filtered out
highpass- everything below is filtered out
bandpass- everything but a certain area is filtered out (ie if 20-50 is bandpassed, all but 20-50 is filtered out)
so, yes, id run 3 way. as for what to bandpass it, does a HU do that or do you need like an equalizer?
and thanks for your help so far
revention
revention
houston
revention
Mike Mccabe
