Mid level SQL Build Input.
kramer_212
Well its been awhile since ive done an sql build, but its time.
Vehicular-2008 Mazda6 (4 door sedan)
factory speaker locations
6x8 front door
.5 tweeter front door
6x8 rear door.
proposed equipment. want to stay under $8000 for entire build.
Head-Unit
Pioneer deh-p99rs ( 4 way active hu)
or
Pioneer deh-80prs (3 way active hu) Plus Audison Bit One Leaning toward this
Amplification
Audison Voce series amplifiers
2 or 3 AV Quattro (4 channel amps)
1 or 2 AV UNO (monoblock)
Audison Voce series
AV 6
AV 3
AV 1
possibly JL Audio zr 8 or AV 5
3-4 AV 10s
or
2-3 AV 12s
Sound Deadning
8 bulk pack (36sq feet) Stinger roadkill
150 sq feet 1/8/1/4 inch closed cell foam.
150 sq feet 1lb mass loaded vinyl
30 lbs of expanding foam
100sq feet of eggshell foam
Enclosures
all doors/enclosures sealed/properly tuned/airspace
Fiber-glassed doors (all 4)
fiber-glassed amp rack/subwoofer enclosure (extra strength)
fiber-glassed trunk sides/trunk-lid etc...
Wires
Stinger HPM 3 series
or
Monster 400 series
or
connection silver series
all oversized.
Electrical
350amp alt 250 at idle
3x stinger spp1750 batteries
Questions/input.
What I was thinking was doing 3 inch/tweeter in each a-pillar a 3 inch/tweeter for the center channel(dash) 2 6.5 inch speakers or 1 8 and 1 6.5 inch in front doors.
and a 6.5 3 and tweeter in the rear doors.
1. should i put a 6.5 and tweeters in the center or leave the 3 inchers.
2. 2 6.5s in front door or a 6.5 and an 8
3. 3 way comp in rear doors or put them in the rear deck (fiberglessed into c-pillar)
4. the bit ten seems to be a better option thoughts?
5. any other suggestions (I;m staying with the voce series) as far as speaker amount/ location im fine with taking away or adding speakers.
6. thinking active the bit ten has 8 channels 10 if you include the center and subwoofer. or should i do a passive system.
Heres a link to the Voce and Bit One
Audison Voce
Audison bit one
any idea why its not mentioning anybody else?
and do you think there will be any problems with imaging?
---------- Post added at 10:11 PM ---------- Previous post was at 10:11 PM ----------
sounds like a really nice ,clean system.wouldn't mind having that either .
I've been summoned...
Well on the deck front... if your going active I would do the p99rs (get it open box/used if you can).
If your not going active get the 80prs
Another good choice would be an older eclipse cd7200 mkii (really warm sounding even moreso than the pioneer) The pioneers will give you more detail by far though but can sound a bit digital, just fair warning.
Since you are looking at 4 channel amps... there's a 6 channel (100x4 + 300x2 @4ohms) below that I would definately buy for a new build its MASSIVE tho...
McIntosh MC4000M Car Audio Amp - $1,100.00 : Tube Mono Block Store, www.tubemonoblockstore.com
I'd go with KNU on the wiring.
I am tring murdermat, but my knowledge of deadners is limited.
I would go active, with p99rs, espicially if you have the money. Speaker placement isn't my strong suit.
The mention isn't working because you need a (space) after the semicolon
I've been summoned...Well on the deck front... if your going active I would do the p99rs (get it open box/used if you can).
The Bit one is an 8-10 channel active processor same 32bit dsp thats why i was thinking it. i actually have a eclipse 7200 but i like my 80prs more personally even though its only 3 way active.
as far as the doors what would you do 2 6.5s or an 8 and a 6.5 and in the center channel theres room for 2 5.25s not sure.
space no work //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Yes I think that processor would probably really help the system and eliminate the need for a p99rs the 80prs should be all you need.
It does not appear to have auto EQ (it has an auto De-EQ but I believe it normalizes the levels without measuring output from the speakers) or I would buy one in a heart beat... I really hate tuning my system currently and the p99rs's autotune is really starting to aggrovate me the more I listen to it.
2 - 6.5's
Keep hope alive will definately be able to guide you on the speakers more.
Yes I that processor would probably really help the system and eliminate the need for a p99rs th 80prs should be all you need.
It does not appear to have auto EQ or I would buy one in a heart beat... I really hate tuning my system currently and the p99rs's autotune is really starting to aggrovate me the more I listen to it.
2 - 6.5's
alright thanks, all help is appreciated.
Anytime, I'm happy to share what I have found.
I think most people may prefer the 80prs because it has bluetooth and thats really nice to have while driving. The p99rs doesnt have bluetooth standard.
If you go with that bit 1 I would find someone with the proper equipment to do the tuning on it.
oh i didn't even know that.
i never use the bluetooth on my 80prs's mostly sd card/ipod/cds.
definitely the 99.the bitt one is a nice touch too.i'd do 8's 6's and some bad *** silk dome tweets .i like to run 2 sets lower in the doors[ just below dash height] personally ,it gives a nice blend of the highs with out being too harsh .might wanna look at the new zed amps too,one of my teammates is an authorized dealer for zed too.
kramer_212
kramer_212
Minnesota
Jroo
