Mephis Audio HELP??
If you're only powering the single 10W7 then why upgrade to an amp purely due to 1 Ohm load stability when you're using a SVC 3 Ohm driver?
It would seem to me that for your particular application 1 Ohm stability would/should be of very little import unless you're planning on making changes to your sub(s) somewhere in the future...
That being said I cannot directly comment on Memphis' Power Reference gear but those that have it seem to enjoy it just fine and I cannot recall hearing/reading an inordinate amount of tales related about equipment failure on that line of gear.
So - all in all you should enjoy it just fine, I would wager. Just bear in mind that the given RMS ratings for that amp are as follows:
300w X 1 @ 4 Ohms
600w X 1 @ 2 Ohms
and
1kW X 1 @ 1 Ohm
Driving an SVC 3 Ohm sub and after factoring in box rise and whatnot I would guess that the Memphis amp you've referenced would give a 10W7 around 350-500w depending on the charging system you have feeding it.
Is that enough to satisfy you?
Tacosys
Tacosys
Cincinnati
Tacosys
