Memphis PR series
I picked up a pair of Memphis Power Reference dvc 4ohm 10s on craigslist for suuuper cheap. I called their tech support and they recommended a ported box size of 1.25 cu/ft each (with sub displacement) with a 9.5 x 1.25 x 19 long port opening. The guy said the box should be tuned to 40hz. However when you put that size port with 1.25 cu/ft its more like a tuning of 33hz. What would you guys recommend for best daily sounding?
model # 15-pr104d
t/s:
Re: 3.5
Fs: 35hz
Vas: 33.4L
qts: .33
qes: .36
qms: 5.58
mms: 95g
BL: 10.19TM
xmax: 9mm
spl: 87db
Sd: (estimated around 310-320 sq cm)
THATpurpleKUSH
Fuckyou
THATpurpleKUSH
Slums of the Shaolin
THATpurpleKUSH
