Already had a few threads on system options but turns out I can mak a big change.
Looks like I will be able to remove my back seat and go with a larger system. 02 2500 Quad Cab. Space that I can install in is 60"(w) x 32"(h) x 20"(d). 32"(h) will keep everything under the rear window and 20"(d) will give me about 3" behind the seats.
I want to use that space for:
Box - 36"(w) x 32"(h) x 20"(d)
Amp rack - 24"(w)
Mount x-overs (components)
fuses and distro block
Second battery
I have been reading through the threads and may consider a ported box. However, I have no exp with ported enclosures. Everything I have done is all sealed.
So why should I go ported? Subs and amps are up in the air but with the specs above what would be best for that box size.
Metal and Rap mostly - looking for sql (total system power @ 2000 wrms)
thanks
Amp rack - 24"(w)
Second battery
thanks
