Memphis Mojo 4000d??
I test mine and got 4300 out of one wired at .5 with a 1.5 reactive load. They draw alot of current so alot of battery power is a must they do alot more power on 16volts I have heard around 7000-8000
they run very smoothly with 16v. and will run fine down to 12v, but under 12v itll start to heat up. get under 11.5v and you run the risk of blowing it. current draw is gonan range from 300amps to 500amps depending on what you're doing with it. Although it takes a large amount of current to make it shine, its not as bad as you'd think. Any amp of this caliber is going to take alot of juice, its not the MOST efficent amp in its class, but its by far not at all an inefficent current hog. I loved mine. did .7ohm dcr at 12v all day long and kicked ***
audioatg
audioatg
NJ 08080
BassAddictJ
