Sold Memphis mcd-4kw $550 SHIPPED!!
Do you know if it would run at half an ohm cause i will be doing a Triple 12 inch sub setup with some old school Phoenix Gold Tielite subs and the final numbers is 0.5 ohms please let me know asap thanks
make sure you have the current to back this beast. these dont like being under 12v very much.
none the less, a very stout amp that i have used and loved.
yea with the right current these things are worth the money. tons of power. mine has never seen below high 12's .had a HO alt with 7 g31's only ran for maybe a few months and never pushed too hard
No, it wont run at a half ohm. The MCD-4KW is unstable below 1 ohm, and is VERY quick to fry if you drop it below. The newer model MC1.4000 will on the other hand run at a half ohm. These amps require a HO alternator and 1 to 2 extra batteries. Anything below 12 volts will throw them into protect mode quick.
Ive seen these run at .5 and do fine with the electrical to back it.
lugnut110189
lugnut110189
cheney, WA
lugnut110189
