memphis mcd 1000 help
after looking around... should this be my setup?
equip is:
Kicker s15l7 4 ohm, box ported at 35hz , powered by a memphis 600watt x 2 ohm
the spec should be
ssf= 26hz
lpf= 80- 90 hz
now the final thing is, how do i measure this with a dmm? lol //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
the ssf and lpf
or should i just turn off the ssf and set the lpf only
Keep the ssf (subsonic filter) on. It will prevent really low frequencies from damaging the sub in a ported box.
70-80 hz is a typical setting for the lpf (low pass filter). Play the system and adjust the setting so the sub blends well with the mids and highs. You want the sub to only be playing the low bass the other speakers can't cover.
how would i measure the ssf and lpf on a dmm?
You don't need to. A dmm is used by some for setting the gain control on the amp. For the ssf and the lpf, just turn the control to whatever frequency setting you want. Look at the range on the the ssf and lpf controls and dial it in as close as you can. Then fine tune it by ear.
xshort_ex
xshort_ex
la,ca
crow
