Memphis 4k fuse
i have argued with you about electrical before. i'm not gonna argue with you guys though, as i am viewed a "noob" to you and it's a losing battle
It's not a losing battle because you're a newb. If you have some evidence, please enlighten us. I have no problem admitting when I'm worng. You just have to prove me wrong first. And a tip of the cap to you if you can.
For the current/amperage to increase as voltage drops, the resistance would have to change. It's not my law. But it's Ohm's. Have you measured a resistance change in low voltage situations?
Since current is voltage divided by resistance... resistance would have to go down to increase the current. And under low voltage and/or high current apps, the resistance is likely to be higher as things heat up. No?
Unless you mean the internal resistance of the battery? Which I'm not sure is likely to drop as voltage gets lower either.
It just occurred to me that you might be thinking that becuase your electrical's voltage drops as the amperage supplied increases that you think the current increase is a function of the voltage drop. When, in fact, it's just consequential.
I'm working all of this out in my head while typing this, man. If you have something I'm missing, I'm all ears.
THANK YOU. I couldn't figure out how to type that out without it sounding complicated.
Low voltage occurs DURING increased current draw, not BECAUSE.
garretttt4
big pimpin
garretttt4
Watertown sd
tommyk90
vegang
vegang
