Memphis 16-mch1300
xxxbasshead
IN TITLE
5-Channel MClass Series Amplifier
Class-AB / Class-D Hybrid Amplifier
Compact Aluminum Chassis with Custon Black Pearl Finish
Gold Plated RCA Connectors
Full MOSFET Design
Fully Variable Crossover: HP/LP (40 Hz - 6 kHz) (Channels 1-4)
Fully Variable Crossover: LP (50 Hz - 250 Hz), Subsonic (20 - 50 Hz) (Channel 5)
4-Way Protection Circuitry
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
Optional Wired Remote Gain Control
RMS Power Ratings:
75 watts x 4 chan. / 300 watts x 1 chan. @ 4 ohms
115 watts x 4 chan. / 600 watts x 1 chan. @ 2 ohms
1100 watts x 1 chan. @ 1 Ohm (ONLY CHANNEL 5 IS 1 OHM STABLE!)
Adjustable Input Sensitivity: 200mV - 4V
Dimensions: 25.81" L x 7.6" W x 2.4" H
325+SHIPPING
SHIPPING PAID BY BUYER View attachment 26549647
Hello,
I'm pretty new to car audio, and I'm wanting to convert my 2 amp setup to 1 amp, however, I have a few questions.
1. Does it push 75w to 4 channels while also pushing 1100w to channel 5?
2. I noticed the subwoofer line in is just one connector. All my amps have the standard red, and white line in for the subwoofer. My Head Unit also has Red/White line out for the subwoofer. How would I wire that?
Thanks for the help.
Hello, yes it will do the 75x4 and 1100 x1 at the same time.
As far as the inputs you could use a 2 to 1 adapter or by plugging in just the 4 channel section it will use the input signal from the 4 channel section.
xxxbasshead
xxxbasshead
lake forst , ca
xxxbasshead
