mechman not charging
juanmgarza26
So I haven't been on for a while I was in a car accident today I was able to get some energy to get started on my truck again, first thing was first, the alt, mechman 270, got it hooked up and wired up with big 2 ran my power cables today and when I turned on the truck the voltage stayed at 12.7 baffled, so I figured I take out my amp and put a load on the electrical system to seeaybe 12.8 was going to be my charging voltage, nope the voltage dropped and got no higher again, the factory alt had the 3 pin oval with an extra yellow lead from the factory harness, I've looked for what this wire is connect ted to and can't find anything
you may wany to check that front battery. if its bad it could be acting as a load on the alt, i had this same problem and it turned to be a bad batt. i took it out and never had the issue again
On my singer I didn't need to use that yellow wire. On stock, it's a jumper, and on the ho alt, I had 3 wires, but Mike told me on mine I didn't need it since it's hooked up another way internally. He had it covered up, but I just wanted to be sure. I have a 03 f150 so I know what 3 wires you mean. I had to cut my stock harness and add the supplied harness.
I know our alts are different but may be similar in hookup.
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
14.6 is max charge for headway. 3.65 volts per cell. There should not be any voltage drop from your alternator wiring to battery so 14.8 is too high.
juanmgarza26
juanmgarza26
McAllen, TX
juanmgarza26
    Apr 28, 2024
    Apr 28, 2024
