Measure Port Displacement?
Decipha
www.EFI Dyno Tuning.com
How do you measure port displacement? Does the area between the port wall count as the internal box volume? Or does it not count since its the port? I'm talking about a slotted port not a round port.
Don't say search cause i already tried that.
if it uses of the sides of the box for one side of its port wall, then:
(port height) x (port length-wood thickness) x (port width + wood thickness) / 1728
if the ports in the middle of the box, and has its own walls, then:
(port height) x (port length - wood thickness) x [port width + 2(wood thickness)] / 1728
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
840
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
843
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
991
Decipha
Decipha
New Orleans, LA
cjjackson85
