mdf vs. partical board
lutz i've seen partical board enclosures actually blow apart from the pressure. just spend the extra 10 bucks or so on a sheet of mdf. you will be happier
yea... particle board enclosures went out a LONG time ago... just get mdf bro... otherwise you'll spend time and money, only to have it most likely fail.
as a matter of fact id put both of them together to get 3" of thickness!//content.invisioncic.com/y282845/emoticons/graduate.gif.d982460be9f153bb54e5d4cb744f6ae8.gif
Birch is accoustically different than MDF, and a properly built MDF box is plenty strong, and real birch (not the cabinet grade at home depot) is expensive as fck.
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
Similar to the Power Acoustik A1800db / A2400db / a3000db / OV1-5500D amps, Planet Audio BB2400, Soundstream PCA2000d, and several others that use...
buckeyes#1
buckeyes#1
p-town
05trailblazer
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
