would these dimensions work for my DD 2515?
marquisbrah
36 inch wide (left to right the way i see it)
16 1/2 height
17 inch length (front of sub to back of box)
Port is 4 inch wide
My current box is
28 inch wide
17 height
22 length
Port is 3 inch wide
I thnk i may have got the width and length mixed up but not sure yet.
suggestions? Might get the first box listed up there depending on suggestions
Thanks
your looking at 4.64 ft cubed before displacement... probably around 4 ft cubed after (depending on bracing, and port).... it should work pretty well... what you trying to tune to?
I think he said the box measurements based on port, tuned to 34.
First one is 4.64ft^3 before sub and port displacement, no way to tell final volume and tuning without more info.
Your box is 4.87ft^3 before sub and port displacements...again, impossible to tell final volume and tuning without knowing more info about the port.
Please tell me what you need to know. Ill try to be as cooperative as possible. Thanks
with the port being 4 wide, and 16 long, you would need a height of 9.5" for a final tuning of 34 hz.... once again... ROUGHLY... need some more info for final... displacement, bracing... etc..
Need to know the height and width of the port opening and the length.
I think you are on the small side once all displacement is taken out.
I'm assuming the first box's port is 16 high and 4 wide length will determined tuning
The box you have I would guess is 15.5 high and 3 wide...again need to know the length.
Ive been texting the guy and he said : port is 4 inches wide, 16 inches in height, and 25 inches deep.
Now about my port: me doesnt know siht. Lol i think its 3 inches wide, and brb getting more measurements
Im going to try to get the length. Its not a straight measurment, i can see from the nails that the port somewhat curves towards the inside of the box
EDIT: it doesnt curve lol.
marquisbrah
marquisbrah
fresno cali
mast240
michigan born
    May 14, 2026
michigan born
    May 14, 2026
