What does it do to the ohm load minimum if you connect 4 Alpine Pdx1.1000's? I'm trying to figure out what the final ohm load ends up at? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Well how would you get 4 amps to push 4 subs exactly the same without strapping or a Slave/master feature? I'm talking about amps that cannot be strapped.not too sure about all that. something new? four amps as one? sounds like it would be a alpine deal. not a general question about strapping an amp.
All that max link is going to do is give you one volume to control multiple. read this.... MAXXSONICS
I thought with the Maxxlink the Master's gain would control the gain for all slaves, and you wouldn't have to mess with the gain on the slaves? It says in the manual that it can make multiple amps into one big amp. One big amp should only have one gain?maxxlink and a dmm
Maybe I'm starting to sound stupid, but I still don't understand the point of the Slave/Master feature?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif When I strapped 2 amps in the past, it seemed like the slave's gain didn't work. I could be recalling it wrong because that was some years ago. The Maxxlink should kill the need for the dmm, right? Well let me ask you this, is it easier to use a dmm on all four amps without the Maxxlink to get the same exact power to all 4 subs?bortado... yes. you use it to control all them BUTZZZ you have to have each amp gains set to match each other amp in order to get the same wattage across all subs. Even then,!, you still have to match impedances. All max link appears to be good for is one controls vs 4 gain controls...
