Sold Max Fidelity Dyne clones NIB
elduderino
PDX
I have some Max Fidelity drivers new in the box, for a project that I never did...tweeters, 5" cast-frame mids, and 7" cast-frame midwoofers. These are all the 4 ohm car units, These are drivers assembled in Canada from parts made in China, and they are Dynaudio clones as the pics show.
The tweeter is the MFDT3NEO 30mm Silk Dome, 80 watts, 90dB SPL 1W/1M, resonant freq of 1440, and fits in a 56mm cutout. Flush mount kit is included.
The 5" and 6" drivers use 3" voice coils, are 90 and 89dB SPL 1W/1M respectively, are rated at 130 W, and use the Dyne-type one-piece cone-dust cap with the VC vents around the edge of the dust cap area. The cast frames are powder-coated.
The 5" fints in a 125mm hole, and has a Qts of .44. The 7" fits in a 135mm hole, and has a Qts of .52 (these are the "high" Qts versions for in-door mounting, rather than small enclosure mouting).
These came with no crossovers. The tweet is spec'd to work with a simple cap, or with a more complex xover. I was going to use them with a PRA-H400, so no passives were needed.
I will sell them as follows:
All drivers no xovers: $300 for all.
Tweeter and 5", no xovers $200
Tweeter and 7", no xovers $225
Tweeters only: $65 the set
5" mids only: $135
7" mids only: $165
If you want a computer-designed, impedance-optimized two-way xover, I have the audiophile-grade parts, and I can supply it - email me.
Paypal only - use el_duderino at comcast dot net to contact me.
elduderino
elduderino
PDX
kappa546
