Massive Audio N2 Mono Amp
In good condition. A few scratches here and there (paint coming off the mounting feet), but in good operating condition. Had it running JL W1 and it powered it very well. I was impressed with it given its size.
Specs
RMS Power Rating (14.4):
4 ohms: 200 watts x 1 chan.
2 ohms: 400 watts x 1 chan.
1 ohm: 800 watts x 1 chan.
Max power output: 1600 watts x 1 chan.
MOSFET power supply with high grade switching devices
LED power/protect indicators
Selectable bass boost (0, 6, 12 dB switchable at 50 Hz)
Designed to fit into restrictive or limited spaces while still delivering staggering amounts of power
Ultra efficient Nano Technology power supplies and endless possible installation scenarios
Monoblock operation
Extreme power in a small footprint
Ultimate mounting flexibility (stackable, line array, side mount)
Mill Spec double sided PCB with SMD parts
Built-In noise reduction circuitry
Heavy duty aluminum alloy heatsink are anodized in a Raven Black finish for extreme heat dissipation
3-Way protection circuitry (short circuit, overheating and Low Voltage)
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Adjustable low-pass filter (40-220 Hz, 24 dB/octave)
Subsonic Filter (10-50 Hz, 24 dB/octave)
Frequency response: 10-220 Hz
THD (Total Harmonic Distortion):
Signal-to-Noise Ratio: >80 dB
Max Voltage: 15V
Max RCA Voltage: 5V
CEA-2006 compliant amplifier
Weight: 7 lbs
Dimensions: 7-1/4"L x 5-1/2"W x 2-1/8"H
Asking $80 shipped or best reasonable offer.
Included in above.
Specs
Monoblock operation
Max Voltage: 15V
Max RCA Voltage: 5V
Weight: 7 lbs
Included in above.
