Sold Massive Audio CA50.4 4 channel high current comp amp
gentlejax
I am going to run 2 amps instead of one. this one has barely been used and was traded to me by a amp collector friend who paid nearly $400 for it
I want $175 shipped
I will post specs in a second
50x4 @ 4ohms 12.5 volts
400 x 4 @ 1ohms 14.5 volts
800 x 2 @ 2ohms 14.5 volts max
thd at rated 0.005%
frequency 5hz-50khz
damping >800
input 200mv-15.0v
fyi people....its rated for 50x4 but it does at least double or triple that at 4ohms...in no way is it a 200 watt amp.....more like 125 x 4 unless you go lower ohms..then its way more than that.....
its 1ohm stereo stable.....fused at 90 amps internally
gentlejax
gentlejax
Bossier City, La.
gentlejax
