Well, it depends on what car, driver, driving environment, and car's condition.
A small 4-cyl car goes thru clutches faster than a bigger engined car. The larger engine has a beefier clutch behind it factory, and has more low-end torque to take off.'
A novice or careless driver will burn up a clutch fast.
A hilly or urban environment is harder than a rural setting. Stop and go driving is awful on any car.
A car in good condtion will have more power, thereby removing need to slip clutch to accelerate.
Use your head when you drive, and dont use the clutch to shift anyways, that's for fake drifters and noobs. I drive everything from a 240sx to my Pete without clutching every gear change. Less times you work the clutch, the longer it lasts.
