ShiningBuick
NotLoudEnuff
A buddy of mine picked up a turbo setup from a 2.2eco today for cheap, kind of an impule buy, but he's going to put it on his 2.4L in a Sunfire.
I did some research so far, and now I'm curious on a few different things that I ran into.
it's a T3/T4 turbo, reletively small intercooler, and and I don't remember who makes the wastegate and BOV. Right now he's planning on running around 5psi for starters, so he doesn't blow stock internals hopefully (he already said if he does he'll upgrade though).
So installing will be the easy(er) part it seems, but once it's in I'm lost on the little details.
Lets see..
2 Bar Map sensor? Will he need this guy? Will this work if so?
http://www.alcohol-injection.com/wat...sensor-57.html
Wideband? Sounds to me like this is an air/fuel gauge? He's got a simple airfuel gauge, does he need this to go along with it?
Injectors? Are there any bigger injectors that fit directly on that are recommended?
Intake manifold.. keep it stock or will it need an upgrade?
Boost controller? Any recommended brands/ setups for this?
PCM.. will it need a an aftermarket one? just a reflash? Is this going to be possible to tune with a laptop/ obdII/ something or is it going to need professional help?
Any other stray sensors/ lines that need to be relocated or anything?
Also, any recommended engine upgrades right off the bat? Cams?
Sorry if I'm ignorant, this is new to me. I tried searching and these are the questions I was left with.
Also, don't bother saying to build the motor up, he's dead set on putting this in, THEN dealing with it once stuff breaks.
Lets see..
