Making my first box!
Tek18
5
KY
Hey guys,
making my first enclosure tomorrow, never built one before, no knowledge.
i need ALL tips, as i do not want to mess up
YES i have a cutout, and layout, and the build pics, very detailed thanks to " Mobile Enclosures ", which i will be writing a great review on him after the build //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so all tips plz! i have 115LBS of the MDF board, 8x4 ft, i think im good.
All tips will be appreciated. thanks!
i will be assembling it first, as in getting all screws in and built no glue, then taking it apart and re-gluing, should i glue with screws in ? etc.
i got my dad to build me one last week, get a countersink bit aswell.
he pre drilled holes, then screwed it together, took it apart, glued it together (cept the top) cocked it all, then glued the top on, screwed it together.
Go in 1 1/2 to 2inches from the corners and predrill the holes or you will risk splitting the wood. Use 1 5/8 coarse thread drywall screws. I like to measure at least 3times before cutting and use screws wherever you can, in combination with the glue. For glue, most use Titebond I/II, I personally use Loctite Heavy Duty construction adhesive, but its cure time is a rather long 7 days.
Tek18
Tek18
KY
THATpurpleKUSH
