Major popping when turning on and off!
It sounds like a power surge running to the speakers when I turn ON the radio and or car and also when I turn OFF the radio and or the car. It's a quick very loud popping! What is this from? I have two amps grounded with a 4g to two 8g distribution block to a sanded portion on the floor door sil. The stereo is powered to the heated seat fuse in the fuse box under the hood.Its a total new install. Any ideas??
could be your headunit mine were doing the same thing among others and i changed my HU and it fixed everything. but your case might be simpler like bad ground or something. what is your remote wire hooked up to?
i had this problem a few times.
one was a bad ground , re sanded and made a new ground to a better thicker piece of steel solved the popping.
second was when i wired in my volt meter few days ago. was a bad connection with the remote wire causing a constant pop from the subs.
Check your connections make sure they are clean as stated without loose strands on + connection as well as the remote wiring.Connections at the battery,ground locations.I have experienced a bad connection at the battery that was a faulty fuse in general
You may try a different grounding point as well.This isnt in my opinion a solid grounding location that Id chosen for any install.That may be the culprit
Sdrolan
Sdrolan
Cape Coral, Fl.
audiobaun
