Mach 5 Audio Logo Competition
MAW-15
It all comes down to moving air. When you can afford the extra space, the MAW-15 will fill your room with low, accurate and powerful bass that you come to expect from drivers costing much more. Its 3" dual four Ohm voice coils allow for a multitude of configurations and the heavy cast frame will ensure no flexing. A very flexible driver suitable for sealed, bass reflex and infinite baffle designs. $79.33
Power Handling: 500 watts RMS
Sensitivity: 90db (2.83 volts)
Impedance: 4 + 4 Ohm
Outside Diameter: 39.4cm (15 1/2")
Mounting Diameter: 35.6cm (14")
Depth: 16.8cm (6 5/8")
T/S Parameters - MAW-15
(coils connected in series)
Fs = 26 Hz
Re = 8 Ohms
Qes = 0.35
Qms = 3.35
Qts = 0.32
Mms = 232.8 grams
Rms = 11.42 kg/s
Cms = 0.159 mm/N
VAS = 129 litres
Sd = 756.3 cm2
Xmax = 13 mm
Cone Diameter = 31.1 cm
Recommended Box Sizes:
Sealed: 62 litres (2.2 cu. ft.)
Ported: 85 litres (3 cu. ft.) 30Hz tuning
EBS: 180 litres (6.4 cu. ft.) 20Hz tuning
If I knew how to use anything on a comp. to make one. I would just say something simple like an MA with a 5 in the background behind them both. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
dam you mark, now the ss board has some major competition.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
btw i am working on a couple as we speak, but i would prefer if the subs stayed logoless.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The largest companies in the world have simple, recognizable logos.
They are easily reproduced in a variety of formats; silkscreen, dye sublimation, vinyl, paint, print, etched-glass, embossment, cnc machined.
Here's my contribution, and I can provide the vector file if you'd like.
Hell, I'll even cut your decals and window signage. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Fonts: RAIDRS, Garamond Pro.
that one is good, but you are giving up ideas to others.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Thank you, NeonRT
Competition brings out the best in innovation, and the worst in men.
The sub is nice, but I'll be perfectly satisfied to be their decal vendor no matter which logo they choose. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
mrogowski
Beware the eyes of Johnny
mrogowski
Winnipeg
theCybe
