Mac AMV Converter
cjzcoc
This page provideos two AMV converter. One is a free amv converter while the other is a powerful shareware. You can free download amv video converter to try for your best choice.
Solution 1: Free AMV Converter
This Free AMV Converter is a Video to AMV Converter and AMV Player that can convert Video to AMV, DVD, AVI, WMV, MP4 to AMV Converter
Free AMV Converter is a easy to use Video to AMV Converter software that help you convert Video to AMV file with excellent video and audio quality. AMV Converter freeware was developed for helping you to convert the video to AMV file format which can be played by MP3 or MP4 Players.
If you have an MP3/MP4 player that supports AMV video playback, then you will need the free AMV Converter to convert videos to AMV file so it will be playable on your player. This version can now encode .AMV files at 128X128 resolution as well. The AMV Converter supports the converting of the following video file formats: AVI, asf, wmv, MPEG1, rm, mov, vob.
It also provides a free amv player.
Solution 2: AMV Converter Free Try and Buy
AMV Converter is a powerful AMV converter tool to convert videos to AMV files. If you want to convert to AMV file, this is the ideal tool. Free AMV converter download is provided in this page.
AMV is a proprietary video format for playback on MP4 player and S1 MP3 players. This AMV Converter free download can help you convert all kinds of videos to AMV files, so that you can watch all your favorite videos on MP4 player. In some case, AMV videos have MTV file extension, you can perfectly get videos playable on your MP4 player, with varied screen size, model or brands.
You can also use AMV Converter to edit videos before converting. All common video editing functions can be achieved, like trimming, cropping, merging, adjusting effect, etc.
AMV Converter Free download is provided here, have a try and enjoy all videos on your MP4 player.
This version works on Windows 2000, XP and Vista, if you are using Apple Mac OS, please choose AMV Converter for Mac.
Key Features of AMV Video Converter
Convert videos to AMV for various MP4 players
All the MP4 player, S1 MP3 player, MTV player, 3G phone, that supports AMV video format, are perfectly supported by this AMV Converter, no matter the screen size and other hardware circumstances.
Support almost all video and audio formats
You can convert all popular video and audio formats to AMV files, such as:
Video: AVI, WMV, ASF, RM, MOV, MPG, MP4, MKV, VOB, 3GP, 3G2, FLV, TOD, MOD, AMV, MTV.
Audio: MP3, WMA, WAV, MKA, MP2, M4A, AAC, AC3, AIFF, AMR, FLAC, etc.
Customize the converting
All video encoding settings are adjustable for you to get videos perfectly fitting your devices. You can freely adjust video resolution, frame rate, audio sample rate, etc.
Video editing functions
AMV Converter enables you to trim the source video to get any segment, crop screen area to cut unwanted parts, merge video clips to output one file, adjust video brightness, contrast and saturation.
Easy to use
With its intuitive interface and optimal profiles, AMV Converter only needs you several clicks to finish the editing and converting.
How to convert AVI,DVD,YouTube,MV,MP4,FLV,MPEG,3GP,MOV to AMV?
Free download AMV Converter, install and launch it.
Step 1. Click "Add" button to input videos you want to watch on MP4 player.
Step 2. Open "Profile" drop-down list and choose AMV as the output format. Click "Settings" button to adjust video resolution and other encoding settings.
Step 3. Click the folder icon in "Output" box to set output path.
Step 4. Click "Start" button to start converting videos.
Tip: Before you convert videos, you can choose a video and click "Edit" button to trim video length, crop screen area, adjust effect, and so on.
After a while, you will get AMV videos playable on your MP4 player from the original videos. And you can use this AMV Converter to edit videos before converting. With professional codecs built in, all the editing and converting can be finished with fast speed and high output quality.
MP4 to AMV Converter, FLV to AMV Converter, MPEG to AMV Converter, 3GP to AMV Converter
Video to AMV Converter was developed for helping you to transform the media files into the AMV file format which can be played by MP4/MP3 Players. If you have an MP3/MP4 player that supports AMV video playback, then you will need the AMV Video Converter to convert your videos to a .AMV file so it will be playable on your player.
Video to AMV Converter can also convert video to audio for playback on your players. The powerful codec pack installed support almost all popular video and audio files like WMV, 3GP, MOV, VOB, MPG, ASF, FLV, AVI, RM, RMVB, MP4, MKV, MKA, MP3, WAV, M4A, AAC, AC3, AIFF, AMR, FLAC, WMA, MP2, etc
What is AMV?
AMV is a proprietary video file format, produced for MP4 players, as well as S1 MP3 players with video playback. There are now two different MTV formats: the older one for the Actions chip, and a newer one for ALi's M5661 chip. This format for ALi one was ALIAVI.
Follow the step-by-step guide to convert video files to AMV/MTV.
Step 1: Download Video to AMV Converter, double click the .exe file to install it.
Step 2: Launch the Video to AMV Converter, click "Add" button to load video clips.
Step 3: Select "Common Video"->"AMV/MTV" from the output format list.
Step 4: You can edit the clip before conversion.
Step 5: Click "Convert" to start converting video files to AMV/MTV.
Free Download:
http://www.video-to-amv-converter.x2mp4.com/download.html
Mac MP3 Converter is currently the best MAC MP3 Converting tool which provides you with easy-to-use interface and comprehensive functions. As a best MAC MP3 Converting tool, MAC MP3 Converter can quickly and easily convert mp3 files on mac to any audio formats, such as wav, wma, ogg, m4a, etc. Besides, converting files between various video and audio formats on Mac is supported by MAC MP3 Converter as well. As a best MAC MP3
Converter, its powerful video editing functions are also above other Mac softwares. Compared with other Mac MP3 Converting software, this tool provides you a professional way to trim videos, crop videos, merge video clips into one. With it, you can edit your mp3 files like an expert. Various video settings options will definitely meet all your video devices' demands. MP3 Converter for Mac provides you only the easiest converting way, but best output quality and fastest converting speed. See the guide of how to convert MP3 on Mac, as below:
Guidence to convert MP3 on Mac.
step 1: Download MP3 Converter Mac, then install and launch it. A screen will pop up like this.
step 2: Click Add File button to add mp3 files that need convert on Mac.
TIP: Mac MP3 Converter supports batch converting.
step 3 :Select any format from the profile drop-down list.and click "browse" to select output folder for the converted loaded files.
step 4: Click
to convert MP3 on MAC, you can see the process of conveting MP3 for MAC from the process bar at the bottom of the window.
Now, the process is finished, see how easy it is, try it!!
cjzcoc
cjzcoc
Beijing, China
cynthiachen2009
