MA Audio Motor and Chrome basket.
CHEMMINS
I have a never used MA Audio HK 18 that I am going to strip down and part out. The motor is heavy azz, takes a 4" coil. The basket is a 6 spoke 18" basket that is chromed.
Items are new, never used.
$250 + ship for Motor
$50 + ship for basket.
Buyer pays shipping.View attachment 26522855
It is new and never used....
The softparts are what hold this sub back. The motor is capable, but the softparts will only take maybe 1500-2000 rms, and 5k burps.
I had it listed for $400 plus shipping or shipped, can't remember.....but selling it in pieces is a lot cheaper for shipping. So essentially I would make the same either way. Lots of people look for a strong motor, and this is it.....and nice basket too.
well, does the basket come with the softparts?
Not if they have to be cut out to remove the basket from the motor. I doubt I will be able to salvage the surround/spiders.....But the cone/coil will be in great shape.
PARAMETERS
KORE 18
Fo (Hz) 33
QMS 4.98
QES 0.87
QTS 0.82
VAS (Liters) 28.76
REVC (Ohms) 5.2 (series)
SPL @ 1 watt / 1 meter (dB) 88.9
X-max Linear pk-pk (mm) 28
LEVC at 1k Hz (mH) 1.9
ENCLOSURE VOLUME'S SEALED
Minimum sealed (Cu. Ft) 1.75
Fill Required (%) No
3dB down point (-3dB Hz) 41
Maximum sealed (Cu. Ft) 2.5
3dB down point (-3dB Hz) 38
ENCLOSURE VOLUME'S PORTED
7 ftcu.
PORT SIZE 15 x 5 x 11.75
tune to fit application custom 42 HZ decrease legnth to raise freq.
SEALED 3 ftcu.
well, i'll keep an eye if ebay doesn't pan out....... the spiders aren't a biggie, but the surround can be salvaged of you are good with a chisel/scraper. i've also separated at the cone before, but i think the hk is stitched,,,,
A Link would be very helpful. Id be interested in taking a look at some gear
183
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
297
CHEMMINS
CHEMMINS
Nevernever Land
akheathen
