Sold MA Audio HK802SX amp for Sale
fox_forma
HK802SX
Specs:
Model: MA Audio HK802SX
Hard Kore Series 4400 Watt Bridgeable 2 Channel High Performance Car Amplifier
1 x 4400W RMS @ 1 Ohm Bridged
2 x 2200W RMS @ 0.5 Ohm Stereo
2 x 1400W RMS @ 1 Ohm Stereo
2 x 800W RMS @ 2 Ohm Stereo
2 x 500W RMS @ 4 Ohm Stereo
Fully Unregulated MOSFET Power Supply
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Stereo
Temperature, Voltage, and Output Level LCD Display
Thermal, Short, and Overload Protection Circuitry
Power/Protection LED Indicators
Stainless Steel Finish Heat Sink
Double Sided Black Epoxy PCB Board
State of the Art Internal Fan and Cooling System
Platinum Plated Screw Type RCA Jacks
Platinum Plated Block TerminalsLow Level RCA Inputs
Selectable LPF/FULL/HPF Crossover
Variable High and Low Pass Filters: 40-250Hz
Variable Subsonic Filter: 20Hz-50Hz
Variable Bass Boost: 0-18dB
Adjustable Input Sensitivity
0-180 Degree Phase Switch
Frequency Response: 20Hz-20 kHz
THD:
THD:
THD:
Channel Separation: 60dB
S/N Ratio: >90dB
Dimensions (L x W x H): 27.3" x 12.4" x 2.7"
This amp is in NEW condition, it has been stored away for a while and was finally brought out a month ago. It is way more than I need and I can't fit it anywhere in my truck. I do not have the box or owners manual, just the AMP itself.
$400 Shipped to any Lower 48. I accept Paypal and MO, paypal please add 3%. You can also look up me forum handle on ebay for feedback there and I bought from IonSql and TeamPSI here. A few others as well but its been a while.
So what would I be looking at realistically at 14.4V bridged at 1 ohm?
Solid 3k. Permitted you can keep your voltage at 14.4. The unfortunate thing was MA or Anaba group rated these amps at 18v. The only ones they didnt was the HK4000d and the HK10. Both had 18 and 14.4v ratings.
I own the HK602 Sx and it has 240A of internal fusing. You do the math and compare the 2. Mine says 3600wX1@1ohm. And these are not class d. Their considered class x. which is a/b switching with discreet digital (class d) processing.
BTW, sorry to dump a little OP, but it is what it is. Those amps will do rated at 18v though. And actually "feel" more powerful then a class d at that wattage.
No dumping Resko, glad you know about this amp and can provide info on it. Wish I could find a bench test on it though at 14.4v, couldn't locate one anywhere. But either way if someone is going to be pushing 3k+ wrms I would hope an upgraded electrical system was in the mix as well.
Their gonna NEED upgraded electrical with that. Its a current hog. Mine was blowing 300a ANL fuses like crazy. BTW, the 802 is NOT internally fused. I only used it as a reference as the 602 is.
fox_forma
fox_forma
Phoenix, AZ
fox_forma
