Sold MA Audio HK4000D
partyboy6686
MA Audio HK4000D
I will accept trades. But only for amps that are 3000+ watts rms @ .5 ohm or 1 ohm. I can add cash on my end if the trade is not even.
Specs:
4000W Digital Class X Competition Mono Block Amplifier
RMS Power @ 14.4V
1800W x 1 @ 4 Ohm
3600W x 1 @ 2 Ohm
RMS Power @ 17.0V
2000W @ 4 Ohm
4000W @ 2 Ohm
Temperature, Voltage & Output Level LCD Display
Thermal, Short & Overload Protection Circuitry
Platinum Plated Screw Type RCA Jacks
Double Sided Black Epoxy PCB Board
Platinum Plated Block Terminals
Fully Unregulated Power Supply
Stainless Steel Finish Heat sink
Quiet Fan Cooling System
Remote Gain Control
Full Mosfet Circuitry
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control at 45Hz
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
2 Ohm Mono Stable
Dimensions: 12.4” W x 2.71” H x 25.86” D
Description/Condition: Used 8.5/10 cos 10/10 mech
Price: $300 + Actual Shipping
Now you pop up! I had a thread about 3 days old, wtt a pair of custom built 15" tc sounds for a class a/b amp with big power. I stated i would take a HK802sx or HK4000d. These are concidered class x design. a hybrid class a with class d processing.
Interested in a trade for 2-15" custom tc sounds subs with aluminum cone assemblies?
BTW, if you know Jamie Robinson around your area, then take a look at his 3hp's i built for him.
if you'll ship first where i can test it and everything works as it should ...I'll paypal you $350 as a gift for the amp....I just got scammed and skeptical of such low post count
Sorry but would need payment first. I barely use this site due to it having a virus a month or so ago that whipped out my hard drive. But i am on CACO also and have refs and itrader over there.
partyboy6686
partyboy6686
Indianapolis, IN
partyboy6686
