ma audio hk4000d,1.33 ohms?
sorry,my options are 1.33 ohms or 2.66 ohms but then i wont have enough power for them if i go with 2.66. thanks.
if this wont work can anyone point me in the right direction for modding my hk?
what would be louder then? my hk at 2.66 on 3 l7's or my hk at 2ohms on 1-solo-x 18? in your opinion?
im only going with kicker because i get such a good deal on it. or else i would be going with dd!
Modding only removes the protection aspect which in turn CAN cause the amp to blow.This isn't really a mod rather removing the protection circuts so the amp won't go into protect.This is the safety feature that PREVENTS your amp from blowing.
Just run it with out modding it. Run it at 2.66 ohms. Are you going out for any comps winning any big money?????? If not just run it at 2.66 then. And if you ever do go to comps I have run them with out modding them below 2 ohms. You have some power behind it. When you do lower the ohm load at comps just watch the voltage you will be fine with 3 secound burps.
nutnbutcustm
IM OLD
nutnbutcustm
Spring,TX.
audioarsonal
