john3387
anyone ever have or heard these subs before
here are the specs
12" Component Subwoofer
RMS Power Handling: 1500 watts
Peak Power Handling: 3000 watts
Reinforced Ribbed High Foam Treated Surround
Bumped Back Plate For Maximum Excursion
400 oz. Double Stacked Strontium Magnets
Patented Thermo-Cooling Motor Structure
Dual Layer Pressed Carbon Fiber Cone
Ultra Strong Carbon Fiber Dust Cap
Hi-Temp Kapton Voice Coil Former
Aluminum Round Wire Voice Coil
Double Layer Progressive Spiders
Platinum Plated Block Terminals
Dual 2-Ohm Voice Coils
Rubber Sealant Gasket
Die-Cast Basket
im thinking about getting 2 and putting it with a MTX Thunder TA 81001
here are the specs for the amp
# of Channels 1
Minimum Single Channel Impedance 1
Class D (Patented Adaptive Class D)
(Pat. No: US06753729) x
Amp Type Optimized for Subwoofer x
Power Supply Semi Unregulated MOSFET
(Pat. No: US05598325) x
THD + Noise (1 Watt) 0.5%
Signal-To-Noise Ratio (1 Watt) 68 dB
Overload Protection x
Thermal Protection x
Xtant Technology Cooling Continuously Variable Fan Speed x
Connection Terminals StreetWires Connectors x
14.4VDC Power 4 ? 500W
2 ? 1000W
1 ? 1500W
4 ? (Two Amps Strapped - wattage is combined power from both amps) 2000W
2 ? (Two Amps Strapped - wattage is combined power from both amps) 3000W
INPUT (RCA Connection) Low Level x
Hi Level w/ Smart Engage (Pat. No: US06556683) x
INPUT SWITCH Input Sense 100mV-1V/1V-10V x
GAIN CONTROL Mono - 100mV-10V x
CROSSOVER Low @ 40Hz-200Hz, 24dB x
SubSonic @ 20-50Hz, 12dB/oct x
EQUALIZATION Parametric: Boost/Cut +/-12dB, Freq. 30Hz-80Hz, Q 0.5-4.0 x
OTHER FEATURES Remote Subwoofer Level Control Parallelable x
Phase: 0 or 180 x
FUSE RATING Total 160
Quantity x Fuse Value 4 x 40
DIMENSIONS Width 20-11/16"
Depth 9-5/8"
Height 2-1/2"
here are the specs
Die-Cast Basket
# of Channels 1
2 ? 1000W
1 ? 1500W
Phase: 0 or 180 x
Depth 9-5/8"
Height 2-1/2"
