ma audio hk-802sx?? 4400w rms????
I am considering each of these amps. There is also a XX colussus 2, which is in similar price range and similar wattage. I am looking to power two 2-ohm DVC, so I need good power at 2 x 1 ohm or 2ohm. I e-mailed MA Audio about the HK802-SX to see what it puts out at 14.4/
i would not by that amp that wattage clame is at 17 volts not the normal 13.8 an average alt wil give or for that matter upgraded alt will only give you about 14.5 to 15 volts at the most thats not close to what you need. if i was you look for a different amp such as the autoteck 4000.1 the are rated at 13.8 volts to put out 4000 rms at 2ohms and will run at 1 for a daly driver to give you around 7 to 8000 rms and just get a little warm to the touch. what subs do you have that require that much power and what ohm load are they.
Your rock called, it wants u to crawl back under.
8k at 1 ohm on 13.8 volts???
Dude, seriously.....where do u come up with this stuff???
Stop talking.....NOW.....before you hurt yourself.
... autoteck 4000.1 the are rated at 13.8 volts to put out 4000 rms at 2ohms and will run at 1 for a daly driver to give you around 7 to 8000 rms and just get a little warm to the touch...
LOL
*sniff sniff*
I smell bullshit!
so do tell me how many VAC and Ampres was it putting out @ the frequency you tested it at?
ya the mm4000.1 needs 360 for daily i have a mm4000.1 and it does its rated power easy at 2ohms
Again cite your source, what VAC and Ampre output are you getting from the amp. Just toss a DMM set to VAC 200v and a clamp metere to ACA, burp at your favorite frequency and tell me the nubmers. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
It'll put out some mad volts too (135)
one of my 9.0s will put out 115vac, not bad for a 2200w amp? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif dont forget the other half of the equation - ampres...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
lifted95blaze
lifted95blaze
Marion, N.C.
supa_c
