M3 or Z1a
i might just get the dual 1s and not really worry about wiring them down for comps
get dual 4's instead of dual one's...still 1 ohm strapped(.5 ohm a amp) but you have more wire in the gap and dual 1 cost more //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
im not to worried about the cost bc i know it wont be to much more... I dont know im really thinking about dual 1s it just seems like i got more opptions down the road if i ever do switch something up
M3s barely do rated power..
the z1a is a good amp..
if you want enough power to push 2 95Gs you should look into a pair of DAT HF2500.1s.. there basically a 3kw board rated fof 2.5.. not to mention there DF and slew rate are superior to the DD.. also the mmats 2000.1s sundown 4500 would do as well after impedance rise..
running amps down to .5 just kills damping and slew rate..
M3s barely do rated power..the z1a is a good amp..
u r dumb u dont know shit about the m3 it actualy will put out more than rated and that amp is fu(king bullet proof even ur dumb *** couldnt **** it up and alot of people run them at .5 daily with no problem and there was a guy running his at .25 daily
DD makes great stuff..
it was benched @13.8@1ohm by usaci and it managed around 2k...
you guys benching amps aren't getting a true rms reading..
those test you saw are upwards of 10%thd
http://usaci.forumotion.com/general-discussion-f11/ddm3-protest-results-t3219-75.htm
now give daddy a kiss..
the DAT 2500 over the m3 anyday cheaper too..
lol, barely do rated power my ***.
yes sir..
Well we got one to do almost 6500 on a 15.7 volt charge on some caps wired down to .17 ohms with rise up to .5. Would you call that Barely rated power? Not to mention on the same wiring running off of 2 kinetik hc2400's we got it to do 4400 watts. Those amps shine at about .5 ohms.
9515ROB
TEAM DTF
9515ROB
Sherman IL
2003F150
