LPF and HPF
low pass filter...
high pass filter...
for setting the range you want your sub to
play within...
if ported you need to set your
amp not to play too much below tuning
frequency... i believe you set it a half octave
below...
for the upper range usually most people
set between 50-80hz...
input sensitivity is how much power the
amp sends to the subs in relation to
how high your HU is... there is an
input sensitivity tutorial on JL audios
website and linked somewhere in these
forums...
yeah this is skeletal info...
Low pass filter set it to like 80hz it plays anything lower than 80hz (this is for subs)
High pass filter set it to like 80hz it plays anything above 80hz (this is for speakers)
so i want it to be set on LPF then. it's got a swtich to turn it to LPF and i think it had a little knob to adjust it too. Wat should i adjust it to? sorry i have so many questions, i just dont wanna blow my sub up. Also, my final question, do i want it on mono or stereo mode?
yes LPF turn it on for ur sub, like i said 80hz is good some ppl like to set it 2 100hz 120hz, try it out and see wats best, jus make sure its not the gain that ur cranking //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Snodude69
Pimpin
Snodude69
Alberta,Canada
audiolife
AJ (ACE)
    Jun 28, 2026
