Lowest watts you were able to pull off hair tricks?
s1ctech
Audio keeed
So whats the lowest power have you guys done to do even just a little hair trick? inside or out. Don't matter just wanna see how good your guys setups are. IF you did it with lower watts explain what you do to achieve such amazing SPL.
A box that takes up half the car can do a lot with little power. I once tried 4 type r 12's in 16 cubes @ 35hz (only 8in port length needed ), was loud but the bass was about a half second too late compared to the rest of the music.
It might be hard to believe but I was able to get hair moving with 1000 watts in my teg. And yes, 15'', BIGAZZ PORT, TUNED LOW AS FAWK!!!!!! Box was a hair over 4 cubes.
Here is a vid of it. My camera's mic brings down the bass to match my highs because they are screaming. The vid was before it was even broken in but it was still doin work back there.
http://www.youtube.com/watch?v=k-cZ1HrAzQI
Kevin
Kevin
where's tha hair trick
Cone area and a nicely designed box does the job. Tuning low will help acheive it better as stated above. 2k total on subs....
yea with the power u had goin to your subs and with your box is just crazy how much air u were moving. I have to agree with every one that says with the right box and car/truck you can move alot of air with 1000-2500 rms.
s1ctech
Audio keeed
s1ctech
Boston
Buck
