I would suggest going with Ohio Generator for the company and I would not turn up the output voltage beyond 16 volts at the alt, this will translate to about a 15 - 15.5 volt amperage across the amplifiers. You don't need to upgrade the starter wire for the stereo but I would increase it for better starter power. Anything over 16 volts can cause damage to y0ur computer in the earlier models and I would not expect to have as much of a problem in vehicles newer than 2003 or 04, but you really need to do some research on your own to find out the computer. The alt upgrade will help tremendously in db and in stabalizing your voltage. The higher your alt is in amps the higher current you can draw from it and with a HK4000d you are looking at drawing 300+ amps of current and I would suggest going with a 200+ amp alt. 250 amp would be better. More current translates into more power, more power = higher db. This is not a 1:1 type statement but this is the normal. If you have 1/0 awg for both power and ground, on the front battery and 1/0 awg from the front battery to the back battery and both batteries are upgraded to a good high output deep cycle gell cell then you should be able to get away with a 200 amp alternator from Ohio Generator and have them build it with a adjustable voltage regulator. Wire the voltage regulator to a display or check it with a DMM, so that you don't exceed 16Vrms, this should both stablize your voltage dip and support your HK4000D with all the power you need to run your stereo at 3/4th volume for daily driving.
