Low-Level Sub-Sonic Filter
there is a product called F-mod I think, they look like an elongated RCA plug, they plug inline with the rca's to the bass amp and do the cutoff before amplification.
I would suggest using winISD to determine options. pre-amplifier options like f-mods tend to have poor slopes. I'm guessing the filters are all overdamped, making them less useful. (eg, the higher slope might be apparent at 5hz, but not at 20hz). winisd provides an estimate of excursion, allowing you to estimate the required filter slope. it also provides options for adding various filters.
it is possible that you can use the HU for this function as well. check to see if you can set the HU up in a 3-way mode or such. you might be able to use the "mid" output (rear?) with a very low highpass and low lowpass, and the "high" with a fairly low high pass. or use some combination of amplifier high/lowpass filters. or use some combination of amplifier filters, hu filters and EQ settings to get the desired effect.
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
592
417
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
5K
Drunken.Swagger
CaDDence Ho
Drunken.Swagger
Dallas
thch
    May 18, 2024
    May 18, 2024
