kmanian
depending on install skill, equipment, and luck, hell yeai didnt catch that.
in that case mid 50's from the 99z
Not to mention 151.2 in the kick and 145+ sealed on the dash.My homeboy TommyK has a pretty loud single 10, 150.6 at the headrest.
Thought the single 10 was peaking at 41?Not to mention 151.2 in the kick and 145+ sealed on the dash.
All at 43 hz. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Perhaps I'll work on it a little bit this year and get that number up. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The new box is peaking at 41, though that note needs to go up me thinks.Thought the single 10 was peaking at 41?
Probably referring to the old BTL motors, which they still didn't make into 10's under normal circumstances.BTL's can be 10's?How do you mount a 10 inch sub with a standard 11.25" high flux motor?
The only HDC3 I've heard was an 18 in 6cuft tuned @38hz, and it wasn't low enough for me daily. I need something that will get about as loud as that, but will play a bit lower. Cameron, you know I'm not really concerned with "mic loud" as much as to my ear. I want the wow factor.Ive did a 41 with a custom psi 10" in a 40hz box. Sub was 5.25 deep!!
Im sure with a deeper sup and correct enclosure you could get a mid 40 without a whole lot of testing. Especially with 2.5k
id get a aluminum coil hdc3
Hmm, I just dont think a 10" is gonna drop low like that and still be the "loud" your used to. Your gonna have to run a good bit cone area.The only HDC3 I've heard was an 18 in 6cuft tuned @38hz, and it wasn't low enough for me daily. I need something that will get about as loud as that, but will play a bit lower. Cameron, you know I'm not really concerned with "mic loud" as much as to my ear. I want the wow factor.
