Loudest I could get on 900 watts
That amp will run at 1.3 with a good electrical system it doesnt draw alot of current so if you have a extra battery you should be fine at running 1.3
Im on stock electrical and cant really afford an extra battery right now
Kenneth is prob right... after imp rise and box rise you will probably have every bit of 2 ohms.. so 3 dual 2s if you wished I guess.
Would I be ok on stock electrical though? I am going to do the big 3 but stock 80amp alt and only one battery
With the impedence rise you will probably get close to a 3 ohm load which would be good for that amp
Test done by a teamate of mine:
Tested on 3 Kicker CVR 12's Dual 4's, all paralled to .667ohms.
Nominal Impedence: 0.667ohms
Reactive Impedence: 1.64 ohms
Output Voltage from Amp: 41AC volts
Output Current from Amp: 25AC amps
Power Output(P=VI): 1025 watts
Current Draw: 84DCA
Voltage on burp: 12.0VDC
Not too bad for an amp rated to be a two ohm amp and playing below its rated impedence. 1000+ out of a 750 watt amp is pretty nice. This amp is 375@4ohm 750@2ohm.
With the impedence rise you will probably get close to a 3 ohm load which would be good for that ampTest done by a teamate of mine:
Current Draw: 84DCA
That's pretty sweet bro.
darkhunter139
darkhunter139
PA
Kenneth10483
