Loudest I could get on 900 watts
Im not sure if I am going to be able to afford 3 decent 10s actually
you don't need as good of quality for the 3 - 10s, fyi.
3 inferior 10s can beat 1 better 15. DON'T EVEN say any crappy 10s will be a BTL but I see guys use lower-end subs that need less power do better in lower power classes.
Well seeing as how you can't get a 2 ohm load with three woofers (dual 12?) then you won't be able to get full power 2 3 woofers from your amp... You could series/parallel 3 dual 4s and get 2.666 or 3 dual 2s and get 1.33... one's to high of an ohmage and the other probably to low. You can't get a Mag because it is only dual 2, so you could get a final load of 1 or 4.. I would probably go for 2 12 d2s in your situation or 2 12 s4s or 1 dual 4 (or dual 1) 15 or 18.. How about an SSA Icon 15 d1? http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=194
Ahh that sucks I kinda wanted the 3 10s
Hmm I am liking the looks of that SSA Icon.
think that would be louder then 2 12s?
darkhunter139
darkhunter139
PA
Kenneth10483
