I remember messaging you about these before, I ordered them Friday, do you have tweeters running too? or just the 6pmsThe DD coaxials I had a while back got very loud, I would imagine it would be the same for the comp set. I have some lanzar opti6pm's here that are pretty beefy that I have yet to amp, I'm pretty sure they will get loud
I tried these for my Accord build and even after modifying the inside of the doors, I couldn't fit them in the factory hole.My massive audio rk6 got loud off 100 watts. I recommed those.
How clear are they (SQ)? They look pretty nice...Look into our ZRS 6KM set...its a dedicated midrange component set. Cadence Acoustics ZRS Series ZRS-6KM, 6.5" Two-Way 150 Watt High SPL Midrange Component Kit
129 shipped...they get very very loud..
As clear as the night sky, through the eyes of the Hubble..How clear are they (SQ)? They look pretty nice...
Yea this is a draw back. The 6.5s are huge. Im lucky i have an impala all i needed was a 1/2 inch spacer and they were inI tried these for my Accord build and even after modifying the inside of the doors, I couldn't fit them in the factory hole.
I'd take a look at Incriminator Audio 6.5 comps. I haven't done a distance test, but when setting eq's, using 180 wpc amp tuned maybe half way, these puppies are loud and clear. I haven't tuned enough to emphasize bass, but my sub does that just fine.
I got mine from Pro Rabbit and he might have another set, if you are interested.
I have a 99 malibu think it'll fit about the same if I add a spacer? 4x6 stockYea this is a draw back. The 6.5s are huge. Im lucky i have an impala all i needed was a 1/2 inch spacer and they were in
I think I would need a spacer as well, but I think I can make them fit.Yea this is a draw back. The 6.5s are huge. Im lucky i have an impala all i needed was a 1/2 inch spacer and they were in
Saw a set of those on CACO, actually local.. no tweeters though, and he wants 160$ for just the mids.. and theyre also used. He also said "The silk dome tweeters distort at higher power load."re xxx 6.5's get loud as **** and don't sound bad either. But they are quite large.
