Loudest 10"
theres no replacement for displacement
JL 10" W7 has 23mm of xmax
brahma 10" has 28.5mm of xmax
TC Sounds 10" TC 3000 has... 34mm of xmax //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif and its optimal sealed enclosure is .112 feet! or .211 feet tuned to 27hz.
TC Sounds 10" LMS 4000 has 30mm of xmax...BUT has a fs of 16hz! and a fairly high QTS so it starts to roll off after most 18s
are you looking for SQL or...just peaky 1 note bass?
I am really drooling over the Tc sounds 15
are you referring to my post? if so...those are 10s!
Im personally found of the LMS 4000 12"
the TC3000 10" will displace 44% more air than a JL 12 "W6v2, 48% more air than a 10" W7 and itll sound awesome while doing it in a SUPER tiny enclosure
although you havent made your point clear as to why you've decided to use 10s
tiny enclosure?
where are you getting the box information for the tc3000?
i heard that tc-3000 15'' needs 5 cube ported.
XMAX measurements have little to do with SPL...MT's have less XMAX than XXX's, but they're louder.
Just saying.
:cough:
XMAX does not equal output;)
depends on a lot of things //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
List your budget and people will throw out some things to look at.
When dealing higher end shit, its more about how loud you can get it....not how loud it can get.
i LIKE this sentence
u might get the 4100 instead, its more effieceint..
shut up.
Diablo6699
Diablo6699
Youngstown, OH
CBFryman2
