Loud trunk ???s
assuming current box is a slot port then make a "temp" reducer to lower port tuning and see if that helps.
My set up is 41Hz and around 36Hz with the reducer which is low tuning for AQ's. Hair tricks are no problem, but it's a wall. Trunk set up won't be so easy, but can be done...
Trunk setup wont be easy? Meh.. dont listen to this old fart //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif Just kidding mike! but yeah... I guess you can call this a hair trick....
more like a sunroof trick //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif My old trunk set up did 149@34hz and wasn't close to doing a hair trick //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Im at 38 hertz now and i can drop it down to 30, after that the port would be too long to just add in.
You remember my 9515g in the trunk wall? it had a massive audio p3000.1 and ended up with a 147.7legal.. not bad for 1 speaker in the trunk.. ur not gunna get that 18 to face forward.. maybe move the box back ane port towards the cabin.. at30-32hz
herbykw
herbykw
Marysville, ca
abrhino
