loud scream from all speakers!
Mr Bojangles
Bullhockey
Help I just hooked up a 4 channel in the titan and i've got a loud scream like it's a problem with the rca's but I bought high end wiring so this would not happen! I know you can buy something that wires in to reduce noise but i don't think something like that will work in this case.. I can hear engine noise, cd spinning, and all other noises.. Anyone had this trouble before?
Help I just hooked up a 4 channel in the titan and i've got a loud scream like it's a problem with the rca's but I bought high end wiring so this would not happen! I know you can buy something that wires in to reduce noise but i don't think something like that will work in this case.. Anyone had this trouble before?
if you unplug the rca's does the noise go away?
if you have an ipod or portable mp3 player, etc, hook it to your amp and see if the screaming continues, if so I would say your amp is boned.
If it doesn't hook your ipod to your rca's up front and test it.
basically isolate and test up the chain to see whats fukd up
ground loop, buddy
never had the luck of hearing a ground loop issue that bad. Didn't think to check that. Thank god I've never had it that bad //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
lemme find you the vid of the sounds my van's ground loop makes...
haha...is that you screamin in the 2nd vid? I've had noise but nothing like that before..that sucks //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
start at the back of the head unit. make sure you have a secure ground for it. keep your RCAs from power wires (I can move my RCAs 6 sinces and hear an increase in noise... so the people who say that its not the RCAs by power wires are wrong.) make sure your amp has a secure ground. are you, by chance, using a pioneer hu?
Mr Bojangles
Bullhockey
Mr Bojangles
H'burg MS
Mr Bojangles
