galacticmonkey
Wants a button like that.
Or to get loud, you can just load your doors up. I had 3 Eminence Delta 10s and a Selenium ST350 tweeter in each door. Around 325w to each Delta 10, and about 60w to the Selenium ST350. Crossed over properly (with my 880PRS), with the 10s playing up to 6khz with a 12db/oct slope, and the tweets playing up from 3.15khz, with a 24db/oct slope, it sounded great.in order for music to leave the car, it needs a direct path out of the car. high frequencies will be gobbled up by the interior. if you can't directly see a tweeter cone/dome from outside the car, you won't hear it as well. this path could also be through the rear hatch/trunk. you could have a "B" system in the trunk/hatch that was for outside gatherings. i've done that before as well. just use some relays to switch between the two systems. open the rear, kill the fronts, and play out the back.
It was loud as heck about 100' behind my truck. At shows I was shutting down cars with 12 12" mids and a bunch of horns/tweets. Also sounded much better.
90% install, 10% equipment.
